systemsguy54
Nov 10, 2020Guide
C7100V is dropping wired connections
I have been trying to reduce my Comcast monthly bill, so I contacted 1-Voip to use their voip service instead of COmcast's. When I received their box to connect up to a wired ethernet port on my C71...
- Nov 11, 2020
No, you shouldn't need to call to reactivate
Nov 10, 2020Guru - Experienced User
Do you have a screen snip of the cable connections page and the logs?
That helps us check the connection back to the ISP
systemsguy54
Nov 11, 2020Guide
I assume you meant connected devices by cable connections screen. So, here is what is currently there:
| Go to Access Control to allow or block devices. | |||
| Wired Devices | ||||||||||||||||||||||||||||||||||||||||
| 2.4G Wireless Devices (Wireless intruders also show up here) | ||||||||||||||||||||||||||||||||||||||||
| 5G Wireless Devices (Wireless intruders also show up here) | ||||||||||||||||||||||||||||||||||||||||
