systemsguy54
Nov 10, 2020Guide
C7100V is dropping wired connections
I have been trying to reduce my Comcast monthly bill, so I contacted 1-Voip to use their voip service instead of COmcast's. When I received their box to connect up to a wired ethernet port on my C71...
- Nov 11, 2020
No, you shouldn't need to call to reactivate
Nov 11, 2020Guru - Experienced User
the provisioning is the file they send that has firmware/speeds for your device.
Your signal levels look good.
Have you tried a factory reset of it? not just a reboot but full reset?
systemsguy54
Nov 11, 2020Guide
I have not tried a factory reset. Should I do that before or after I ask them to re-provision, or should I wait until the factory reset to see if it all comes back before asking them to re-provision?
- plemansNov 11, 2020Guru - Experienced User
i would start with the factory reset. Push and hold reset for 7-15 seconds while its powered on. The lights should change/flash when held long enough.
You don't have your wired devices connected through a switch do you?
- systemsguy54Nov 11, 2020Guide
No, the wired connections are directly into the router itself. One question for you... This router is one that I had purchased to get rid of the Comcast provided one (no sense in paying them a $10 fee every month ad infinitum). If I do a factory reset, do I have to notify Comcast (I initially had to call them to have them activate my router in their system). I assume that I would not since it does not change MAC address, but I need to ask anyway.
Thanks,
Paul
