NeilG-Rrouter
Jun 10, 2020Aspirant
C7100V Keeps on Turning off and on
I have firmware V2.01.42 and router keeps on turning off repeatedly resulting in admin login, router naming, and router passwords being reset to factory settings. What can I do to resolve this as th...
Jun 10, 2020Guru - Experienced User
Disconnect the coax cable from the modem. Factory reset the modem, press the reset button for 15 seconds then release. Wire connect a PC to the back of the modem. Use a web browser and log into the modems setup page and walk thru the setup wizard. Can you complete this wizard?
Does the modem reboot on it's own with the coax cable disconnected?
NeilG-Rrouter
Jun 11, 2020Aspirant
Took out cable and router continues to restatr repeatedly. Then took out the yellow cord to computer and unplugged, and reset and contunies to restart. What do I do?
- FURRYe38Jun 11, 2020Guru - Experienced User
Unit need to be replaced. Contact NG support and ask about a RMA.
