Homeuser66
May 06, 2020Guide
C7100V Modem Keeps Randomly Restarting
Randomly, my C7100V modem will reboot. I can't figure out why. I went into the EMTA Event Log and don't know what I'm looking at. Could someone tell what it is? Did it take an update or something? I ...
May 11, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Channels above 11 are not seen or used in the USA. Only in EU regions.
Can you turn down the radio power Under Advanced Tab/Advanced Settings/Wireless Settings?
Homeuser66
May 18, 2020Guide
I guess you're done with me and can't help me any longer? I sent you pm as well you didn't reply. I was trying to give you what you asked for, but didn't find what you needed.
Thanks for trying
Thanks for trying
- Homeuser66May 18, 2020GuideComcast was out today. Levels are fine. 1 broken pretty at tap he said corks be causing the issue. But he's not sure.
- FURRYe38May 18, 2020Guru - Experienced User
"1 broken pretty at tap he said corks be causing the issue." Huh?
So did he fix this issue? Have you seen any more issues with wifi or the modem restarting since the tech was out to visit?
Yes, pick one of the 3 channels I mentioned with the lessor of other wifi users on them. I wish your modem had power level settings. Would be helpful in a wifi congested area.
- Homeuser66May 18, 2020GuideHe didn't fix the broken port, he had to set that up for a line tech. I'll have to wait and see. But since I replaced the 90 degree angle connector he put on when they installed it, my levels got better. Thanks for your help. I'll keep you posted.
:smileywink:
