ICanGamez
Aug 24, 2022Follower
C7100V Modem router combo. internet drops randomly
So I have a C7100V Modem router combo. I get around 111.1 Mbps Download speed but only 8.9 Mbps upload speed. The router is in the middle of my house (which isn't big) and my bedroom is right next to...
Aug 25, 2022Guru - Experienced User
Same with what Kitsap said, a screensnip is the best way to help.
Get a screensnip of the cable connections page and the event logs.
You can try checking your cable connections as well.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
