Gonzalez03
Oct 04, 2022Aspirant
C7100v no intenet connection
I unplug the power when I reconnected the intenet don’t come up Please help
Gonzalez03
Thank you sr
All lights are on but no internet connection
What i do ?
What i do ?
Oct 04, 2022Guru - Experienced User
Disconnect the ISP coax cable from the back of the modem. Factory reset the modem using the back reset button and press it for 10 seconds, then release. Have 1 wired PC connected to the back of the modem.
Does any of the LEDs change behavior here?
If so, see if you can access 192.168.0.1 or 192.168.1.1 in a web browser with the one connected PC.
See if you can walk thru the setup wizard here...
