Smcilree
Aug 10, 2023Follower
C7100V No Internet on WiFi
I own Nighthawk AC1900 DOCSIS 3.0 High-Speed Cable Modem Router + Voice (C7100V) to access my Xfinity account. It has worked well since I bought it in December 2019. Recently, it has developed a stra...
Aug 11, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the modem been performed ?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
