Pugless55
Feb 07, 2020Aspirant
C7100V no longer can edit wireless access list
Firmware version on the router is 2.01.42. Model is a c7100v wifi/router/voice. I have always been able to edit the wireless access list to add new devices. Now for some reason I cannot edit or add a...
Feb 08, 2020Guru - Experienced User
What browser are you using? Try IE11, Firefox or Opera.
Besure to clear all browser caches, exit and then relaunch the browser.
- Pugless55Feb 10, 2020Aspirant
Thank you for the reply. I did as you suggested and still could not edit or add to the list. Tried IE 11, Safari13.05 and Chrome 80.0.3987.87. Even tried factory resetting the router and tried adding a device to the list and it would not. Oddly enough after factory resetting and reloading the backup config file II was able to add (1) new device then after multiple tries could not add another one to the list. Doses not make any sense?
- DarrenMFeb 21, 2020Sr. NETGEAR Moderator
Hello Pugless
Can you provide some steps you take when you see this bug and maybe some screen shots our engineers are looking into this issue.
Thanks
Darren
- FURRYe38Feb 21, 2020Guru - Experienced User
Any progress on this?
Pugless55 wrote:Thank you for the reply. I did as you suggested and still could not edit or add to the list. Tried IE 11, Safari13.05 and Chrome 80.0.3987.87. Even tried factory resetting the router and tried adding a device to the list and it would not. Oddly enough after factory resetting and reloading the backup config file II was able to add (1) new device then after multiple tries could not add another one to the list. Doses not make any sense?
