mike_newuser
Jul 15, 2019Guide
C7100v not detecting USB hard drive
I recently switched ove to a cable / voice modem. C7100V and according to the information I can find it is supposed to see HDs connected to the USB port. I hav tried three different WD drives and it ...
mike_newuser
Jul 19, 2019Guide
Sorry about taking so long to reply had to get another router so I will try it out later today after install.
The USB drives were both usb 3 and no external power.
Jul 21, 2019Guru - Experienced User
Can you find a USB 2.0 drive to test with to see if this version works or not?
