mike_newuser
Jul 15, 2019Guide
C7100v not detecting USB hard drive
I recently switched ove to a cable / voice modem. C7100V and according to the information I can find it is supposed to see HDs connected to the USB port. I hav tried three different WD drives and it ...
Jul 21, 2019Guru - Experienced User
Can you find a USB 2.0 drive to test with to see if this version works or not?
- mike_newuserJul 23, 2019Guide
Still an issue waiting for a level 2 tech to call as ready share is not working properly as well.
Level 2 tech - they are sending another router and I am supposed to return this router. Could not get the router to work properly with the USB drive(s).
So until next time.............
