Havingfun12-31
Dec 31, 2020Follower
C7100V Parental Contol - NetGear Gennie conflict
The Parental Contol tab in the NetGear Gennie opens an internet page directing to download Circle on Netgear App. The App however says that the C7100V is NOT a supported device, so you can't use th...
Dec 31, 2020Guru - Experienced User
You'll need to probably ignore what the app is doing. Genie is being retired and not developed on anymore. Circle isn't supported so it's recommended to manage the modem using the modems web page only.
Good Luck.
