Jetguy
May 08, 2023Aspirant
c7100v Phone Jacks question
Hi all, I'm looking to buy a Netgear c7100v cable modem to use with my Xfinity service because it has phone jacks. I have the c7000v now(no phone jacks). I want to drop my landline carrier and por...
May 08, 2023Guru - Experienced User
Not fully sure if they are can be or not. I believe the ISP will know this information about the phone jacks. If they can't be you can always just install a phone line splitter in one of the phone ports.
- JetguyMay 08, 2023Aspirant
Thanks Furrye38. Yes, thats what I'll have to do. Call them to find out but you know how that goes sometimes.
- FURRYe38May 08, 2023Guru - Experienced User
- plemansMay 08, 2023Guru - Experienced User
What I'd do instead of that is go with a voip phone setup like ooma or one of the other ones.
It'll be cheaper than xfinity's setup and will let you continue to use your device or upgrade to a docsis 3.1 modem in the future.
- JetguyMay 10, 2023Aspirant
Plemans, Yeah I've thought about that too but I think I am just gonna stick with xfinity because my billing etc is all setup with them. I don't really want to go into another payment contract with another provider.
Thanks for your thoughs!
