Jetguy
May 08, 2023Aspirant
c7100v Phone Jacks question
Hi all, I'm looking to buy a Netgear c7100v cable modem to use with my Xfinity service because it has phone jacks. I have the c7000v now(no phone jacks). I want to drop my landline carrier and por...
May 08, 2023Guru - Experienced User
Not fully sure if they are can be or not. I believe the ISP will know this information about the phone jacks. If they can't be you can always just install a phone line splitter in one of the phone ports.
Jetguy
Thanks Furrye38. Yes, thats what I'll have to do. Call them to find out but you know how that goes sometimes.
- FURRYe38May 08, 2023Guru - Experienced User
- plemansMay 08, 2023Guru - Experienced User
What I'd do instead of that is go with a voip phone setup like ooma or one of the other ones.
It'll be cheaper than xfinity's setup and will let you continue to use your device or upgrade to a docsis 3.1 modem in the future.
- JetguyMay 10, 2023Aspirant
Plemans, Yeah I've thought about that too but I think I am just gonna stick with xfinity because my billing etc is all setup with them. I don't really want to go into another payment contract with another provider.
Thanks for your thoughs!
- plemansMay 10, 2023Guru - Experienced User
What speeds do you pay for with xfinity? Reason I ask is they're increasingly requiring docsis 3.1 for some of their speed tiers. If you're needing a docsis 3.1 device AND phone, you might have to use one of their devices if you go that route.
