Greg100
Sep 13, 2023Follower
C7100v power light only on
Modem suddenly has solid red power light only. No other lights on and devices don't recognize it. Have tried unplugging and replugging and also reset button several times. Modem is less than a year old. Solution?
Thanks for any help.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
You might like to search there for messages related to your problem. - FURRYe38Guru - Experienced User
Contact NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
