XboxOneUser
Nov 12, 2021Aspirant
C7100v refuses to disable UPnP
Was instructed to make this post here by another member. When I try to disable UPnP by going into the UPnP tab in my advanced router settings and unchecking the "Turn UPnP on" box, then hitting apply...
XboxOneUser
Where might I find these security controls the modem may be using and which ones should I be looking out for in particular? There's a lot of stuff here and I don't want to turn off something important
Nov 14, 2021Guru - Experienced User
Anything that appears with Armor, though I don't think Armor is supported on C series modems.
Access Controls maybe seen under Advanced tab/advanced settings/Security. Parental controls maybe here as well if supported.
