kmspgh
Nov 09, 2023Aspirant
C7100V Stuck in a Boot Loop
Our C7100V Cable Modem keeps trying to boot and fails, likely due to a firmware upgrade that went . Unable to see it to login. It looks like I will need to connect my windows 11 laptop to it by a ...
Nov 09, 2023Guru - Experienced User
You'll need to contact the ISP for this. ISPs are the only ones that can push FW to C and CM series modems. There is no user UI for user updates.
Disconnect the coax cable and power OFF the modem for 1 minute then back ON with out the coax cable connected, does this stop the boot loop?
kmspgh
It does not. I have tried every potential solution. Unfortunately, Comcast tells me to contact Netgear.
