KEVHARPER
Jun 06, 2019Aspirant
C7100V Xfinity Voice Fax Problem V2.01.40
Hello- I have a C7100V I have been using in bridge mode since beta testing on the unit. It was working great for me with XFinity voice. Last year I sent several faxes with no issue. I was havin...
DarrenM
Jun 12, 2019Sr. NETGEAR Moderator
I will check with engineering on this.
DarrenM
Oct 06, 2019Guru - Experienced User
- Bikeman_I7Oct 27, 2019Aspirant
Any Updates From Engineering on this Particular Issue?
Gateway working fine otherwise, but does have communication error when trying to send faxes in bridge mode, currently using it in Router mode at the moment, til after RL move, then may resetup into bridge mode with Router possibly, but would like to have Faxes able to work in case needed after our real life move completes
