davehomiak
Jun 26, 2018Aspirant
C7100V Xfinity WiFi not working for 2.4 GHz, but 5 GHz is fine
My router is really a Nighthawk AC1900 WiFi (C7100V) for Xfinity, bought on 6/10/2017, so it is now out of warranty. It has the latest version of the firmware. A few days ago, the 2.4 GHz WiFi stoppe...
vkdelta
Jun 26, 2018NETGEAR Employee Retired
Please post network logs here.
also post wireless configuration screenshots and advanced wireless configuration. You can Remove password/personal from the screenshots.
davehomiak
I have attached an RTF file with screenshots of my C7100V's wireless settings and logs (can be resized for easier reading), taken after a factory reset. The 2.4 GHz radio is still not on. It's front panel light goes off as soon as the DS/US light starts flashing, while the 5 GHz light stays on. Note in the wireless settings that the 2.4 GHz mode is not set, while the 5 GHz mode is; if I try to set the 2.4 GHz mode, then the 5 GHz mode gets set to a low value. Same nonsense happens if I try to set channels for the two radios. Let me know if you have any ideas.
Thanks.
- vkdeltaJun 27, 2018NETGEAR Employee Retired
Please PM me directly.
