TUCSONTECH
Jun 21, 2024Follower
C7110 V reports Invalid IP address creating port forwarding rule
I'm trying to create a port forwarding rule to allow VPN access to my Windows 2012 Server. I'm creating a custom rule, specify the port and attempt to specify the IP address of my server and receive ...
Jun 24, 2024Guru - Experienced User
What happens if you change the static IP address on the Server PC to .10 after configuring a PF rule to .10?
Be sure you disable uPnP on the modem as well.
