kokabemi's avatar
kokabemi
Follower
Mar 10, 2020
c7500 - lagging
I recently purchased this modem/ router , I had high expectation for it as it was quiet expensive. Wifi rage is great however however, it lags when browsing, sometimes upto 10 sec to display a website , results are bit better when the laptop is hardwired. I tried to change the dns in but it wont save the changes. Running a speed test at speedtest.net will time out . I'm thinking about returning this modem, never had this issue with the cheap one I had before.
1 Reply
  • plemans's avatar
    What ISP are you using?
    What speeds do you pay for?
    What speeds do you get hardwired into the device? (I get that it times out but try hardwired)
    If you log into the modem connections page, take a screen snip of this. it shows us the connection back to you isp. Also take a screens snip of the logs.
