PeggyC
Oct 07, 2023Aspirant
C7500 firmware issue?
About couple weeks ago, I am starting to have issue with my network, and now that my 5G is just gone (not visible). When I am looking into the C7500 webpage, I see that my firmware version is V1.01....
PeggyC
Oct 08, 2023Aspirant
Is my ISP the Internet Service Provider (COX)?
the 5G LED is good, solid white light.
When I say not able to find, I am using my home device (ie. computer, cellular phone), none of them is able to see the 5G network ID. Only 2.4 network ID.
Peggy
Oct 08, 2023Guru - Experienced User
Factory reset the modem and setup from scratch using a wired PC and web browser at 192.168.1.1.
Please give feedback to the linked items that were give as well.
- PeggyCOct 08, 2023Aspirant
Did reset the modem a couple of times. By pushing the button at the modem, and remotely from the ISP service. No change.
From ISP side, it is reporting no issue with the network. When go into modem's page, I see connection are good for 2.4G and 5G, showing the network ID name and etc.
But, when I use the home device (ie. computer, cellular phone), I can only see the 2.4G network ID, no 5G network ID.
My 5G network is still saved in my computer as I had it connected before. Nothing changed. But, now it is telling me that my 5G network is not available.
Peggy
- FURRYe38Oct 09, 2023Guru - Experienced User
Last resort would be to try a 30-30-30 reset on the modem. If this fails to bring back the 5ghz radio, then it's probably busted.
Couple of options, Disable all wifi radios on the modem and install a wifi system in AP mode connected to the modems LAN port.
Or configure modem only mode and install a new external wifi router system and continue to use the modem for ISP internet services to the external wifi router system.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
