AngryNarwhal
Sep 17, 2019Aspirant
C7500 Lights on NO internet
Hey forum folks, So I'm in a serious pickle (and seriously unimpressed with the madness of netgear's expensive support plans) with my C7500 Nighthawk. Here are the details: Lost internet 7pm Sa...
michaelkenward
Sep 18, 2019Guru - Experienced User
While there is a lot of detail in your message, there is very little useful information.
Let's look at one bit:
AngryNarwhal wrote:
Most of the articles seem to require logging into the router/ISP address which I am entirely unable to do no matter what I try.
What happens when you try this?
What are you doing?
Any error messages?
- AngryNarwhalSep 18, 2019AspirantSo basically when I try to go to routerlogin I have my computer connected to the router via ethernet cable. However I cannot see my own network listed in the options of networks to connect to. Trying to get into routerlogin bring ups the same "cannot load page" type of message that attempting to go to any other website without network connection would.
Basically it seems that my router won't recognize an ethernet cable in any port. It acts like it's connected to the internet but won't connect to any devices via ethernet or wifi. Wifi won't even turn on. I can't even find my network to TRY to connect to.
I'm sorry if this still isn't useful but at this point it's all I've got. Please ask away if there's more info I can provide!- michaelkenwardSep 18, 2019Guru - Experienced User
AngryNarwhal wrote:
I have my computer connected to the router via ethernet cable. However I cannot see my own network listed in the options of networks to connect to.That's not how routerlogin works.You will not see any network to connect to. That's a wifi thing.
http://routerlogin.net (or http://routerlogin.com) should bring up the graphical user interface (GUI) for the C7500.
If they do not work, then an alternative is http://192.168.0.1.
AngryNarwhal wrote:
Trying to get into routerlogin bring ups the same "cannot load page" type of message that attempting to go to any other website without network connection would.What is that "type of message"?
These messages are not random. The exact wording may well tell us something about why your modem/router is rejecting the connection.
Is there anything else on your network?
- FURRYe38Sep 18, 2019Guru - Experienced User
What happens if you try 192.168.1.1 or 192.168.0.1 in a web browser?
