bloodyknuckles
Apr 29, 2020Aspirant
C7500 no wifi or ethernet
Came home today to find my modem/router not functioning properly. It's getting internet signal but none of my devices can get wifi or hook up using ethernet. I also can't get to the page to access the...
Apr 30, 2020Guru - Experienced User
Try unplugging the coax from the modem. When powered on push and hold reset for 7-15 seconds. The lights will change when held long enough.
Then connect the coax and reboot it.
try accessing it 192.168.100.1
Can your isp see/ping it?
- bloodyknucklesMay 01, 2020Aspirant
When I followed these steps and hit reset, the top 4 lights only flash for a few seconds then stay white. So, after following all these steps it still didnt work and couldnt access the router. My ISP can see the modem.
plemans wrote:Try unplugging the coax from the modem. When powered on push and hold reset for 7-15 seconds. The lights will change when held long enough.
- plemansMay 01, 2020Guru - Experienced User
solid white on the top 4 tend to indicate good things. (see the manual for specifics)
If you hardwire into the c7500, can you access it from 192.168.100.1?
Have you tried a different laptop/pc?
Did the wifi on/off button get pushed somehow? push and hold it for 2 seconds.
As well as there's a led button on it with 3 modes.
plemans wrote:solid white on the top 4 tend to indicate good things. (see the manual for specifics)
https://www.netgear.com/support/product/C7500
But the lights for 2.4/5.0 are not on. Wifi button isn't doing anything nor the other two. I only have one laptop and eithernet not working. Also the white light stays on indicating somthing is plugged into the number 2 port on the back but nothing is plugged in.
