bloodyknuckles
Apr 29, 2020Aspirant
C7500 no wifi or ethernet
Came home today to find my modem/router not functioning properly. It's getting internet signal but none of my devices can get wifi or hook up using ethernet. I also can't get to the page to access the...
Apr 30, 2020Guru - Experienced User
Try unplugging the coax from the modem. When powered on push and hold reset for 7-15 seconds. The lights will change when held long enough.
Then connect the coax and reboot it.
try accessing it 192.168.100.1
Can your isp see/ping it?
bloodyknuckles
May 01, 2020Aspirant
When I followed these steps and hit reset, the top 4 lights only flash for a few seconds then stay white. So, after following all these steps it still didnt work and couldnt access the router. My ISP can see the modem.
plemans wrote:Try unplugging the coax from the modem. When powered on push and hold reset for 7-15 seconds. The lights will change when held long enough.
- plemansMay 01, 2020Guru - Experienced User
solid white on the top 4 tend to indicate good things. (see the manual for specifics)
If you hardwire into the c7500, can you access it from 192.168.100.1?
Have you tried a different laptop/pc?
Did the wifi on/off button get pushed somehow? push and hold it for 2 seconds.
As well as there's a led button on it with 3 modes.
- bloodyknucklesMay 01, 2020Aspirant
plemans wrote:solid white on the top 4 tend to indicate good things. (see the manual for specifics)
https://www.netgear.com/support/product/C7500
But the lights for 2.4/5.0 are not on. Wifi button isn't doing anything nor the other two. I only have one laptop and eithernet not working. Also the white light stays on indicating somthing is plugged into the number 2 port on the back but nothing is plugged in.
Potentially it is bad. It does happen sadly.
You can click "mynetgear" at the top, register an account and then the device. From there you can see if you're still within your warranty period as well as start the rma process.
