NoyS_609
May 24, 2023Aspirant
C7500 UI not responding and broadcasting 2.4G
A few days ago I've noticed that some of my devices running on 2.4G Wifi got disconnected. I routerlogin.net to my router and can't find 2.4G setup anymore. I did factyory reset, which didn't helped. ...
- Jun 01, 2023
it's okay, I'll figure it out. everything works on my ISP part except for the router login. what I'm noticing is that it's trying to redirect the page but couldn't open it so it leaves the settings area blank.
May 25, 2023Guru - Experienced User
Try pressing the reset button in back of the modem for 10 seconds then release. When the modem has become semi ready, pull the power cord from the wall out let for 1 minute then back in. Walk thru the setup wizard with a wired PC and web browser and complete it.
- NoyS_609May 25, 2023Aspirant
I've tried the steps you've provided several of times and still no luck. The 2.4GHz light is still not coming on and the UI is still not responding the way it should. I'll get blank a page in almost every tab I go into. The one's I can see I cannot save the changes because the "Apply" does nothing/doesn't work. Once I entered in my credentials; I get a blank page as well. Any other solution how we can resolve this?
Please see attached screenshot. 3 pictures in 1 screenshot
- KitsapMay 25, 2023Master
Be sure and clear the cache in your web browser. Which ever browser you are using, try a different one.
I had already tried wiping out all of my browsing history, temp files, and even cleaned up my local C:\ but still getting a blank page in every tab. I've tried different browser and laptop, still got the same result. Was something changed recently on Netgear end such as updates? Everything was working until this past Tuesday 29th.
