appendixman
Nov 25, 2020Aspirant
C7500 Wifi dropping while ethernet still working
Hi All, I have the Nighthawk X4-AC3200 C7500 modem/router combo on Spectrum Cable. It has been working well for the past year but over the past two weeks I've been having a problem where the wifi...
Nov 26, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed?
- appendixmanNov 26, 2020Aspirant
Thanks for your reply! I was previously using auto then switched to 2.4ghz channel 2 and 5ghz channel 153, as there were the fewest competing networks on those channels. There are 13 2.4 ghz neighbors and 32 5ghz neighbors. I did do a factory reset and setup from scratch but the problem has persisted.
- FURRYe38Nov 26, 2020Guru - Experienced User
1, 6 or 11 on 2.4Ghz and 36 thru 48 on 5Ghz.
