anthonysi's avatar
anthonysi
Follower
Sep 09, 2020
C7500 wifi drops
Hi team,
For the last month, my laptops have been dropping connectivity to the router. Although the wifi name is visible, it will connect and disconnect and sometimes ask me to reenter the credentials.
How can I determine if this is a hardware issue or if my ISP is not serving traffic (router logs or diags)?
1 Reply
  • FURRYe38's avatar
    Is it only wifi that seems to have a problem or does a wired PC or laptop see the same this when this happens?
    Has a factory reset and setup from scratch been performed?
