braddman
Jul 25, 2021Star
C7800 - Cannot connect to 2.4Ghz anymore.
Firmware Version V6.01.07 So this is super annoying. I cannot connect to the 2.4ghz wifi anymore with my phone. 5ghz works fine. A lot of devices are still connected to 2.4 but I just canno...
braddman
Aug 01, 2021Star
I think I figured out what's happening. I found in another thread that Netgear gives no fs about bugs. Apparently you can't connect more than 20 devices to 2.4 and this starts happening and they never fixed it. I connected a few of my smart home devices to my wifi extender instead and I'm able to connect now. It utterly blows my mind that this has not been fixed.
Aug 01, 2021Guru - Experienced User
One reason it may not be fix is that there maybe a HW limitation on how many devices you can connect to one radio at a time. You can't just connect unlimited amounts of devices to one WiFi radio. There are some limtations. Not all wifi can handle large qualities of devices. Been like this for years. Nature of the beast.
One thing you might do is connect a wifi extender, like you did, this helps off load some of the wifi devices to a different wifi source to share the band width.
