braddman
Jul 25, 2021Star
C7800 - Cannot connect to 2.4Ghz anymore.
Firmware Version V6.01.07 So this is super annoying. I cannot connect to the 2.4ghz wifi anymore with my phone. 5ghz works fine. A lot of devices are still connected to 2.4 but I just canno...
Aug 01, 2021Guru - Experienced User
One reason it may not be fix is that there maybe a HW limitation on how many devices you can connect to one radio at a time. You can't just connect unlimited amounts of devices to one WiFi radio. There are some limtations. Not all wifi can handle large qualities of devices. Been like this for years. Nature of the beast.
One thing you might do is connect a wifi extender, like you did, this helps off load some of the wifi devices to a different wifi source to share the band width.
braddman
Aug 01, 2021Star
There's a hard limit but it's not 20. It's supposed to be supposed to be 32 per band..
