Cookan
Jan 18, 2023Follower
C7800 - Turn Off Lights on Antenna Tips
I want to turn off the blue lights that are on top of the four router antennas. The router is in bedroom and these bright lights make it difficult to sleep. Is it possible to disable / turn these ante...
Jan 18, 2023Guru - Experienced User
Black electrical tape works pretty well 🙂
I did that for a bit on mine to limit the led light.
