GerryPedraza
Aug 10, 2020Aspirant
C7800 2.4Gz Network goes to channel 0 and stops working
This has been a consistent behavior. At some point during operation the 2.4 Ghz Network goes down into channel 0. I use it on auto. I cant change the channel after it fails. I try and it does not...
Aug 10, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed?
- GerryPedrazaAug 12, 2020Aspirant
Hi,
Thanks for your question.
Right now it just shows my 2 networks.
I'm sure the neighbors have their routers but for some reason I cant see them. at the moment..
Tried with my computer and phone...
I have not performed a factory reset. I can try that thank you. I really haven't set customized options considerably that's why I haven't done something like that, but I appreciate the suggestion.
Thank you.
G
