GerryPedraza
Aug 10, 2020Aspirant
C7800 2.4Gz Network goes to channel 0 and stops working
This has been a consistent behavior. At some point during operation the 2.4 Ghz Network goes down into channel 0. I use it on auto. I cant change the channel after it fails. I try and it does not...
vkdelta
Aug 11, 2020NETGEAR Employee Retired
can you set it to specific channel instead of AUTO? such as CH7, CH4, etc.
GerryPedraza
Aug 12, 2020Aspirant
Yes. I can do that before it breaks. But eventually it goes to channel 0.
- vkdeltaAug 12, 2020NETGEAR Employee Retired
Please DM me your CM MAC + Cox account.
- GerryPedrazaAug 12, 2020Aspirant
Info sent. Thank you for your message.
- DarrenMAug 12, 2020Sr. NETGEAR Moderator
Hello Gerry
can you send me a PM with the info below our support team wants to look into the issue
- C7800 S/N
- FW version
- MSO/ISP
- Phone
DarrenM
Info sent. Thank you for looking into this.
