GerryPedraza
Aug 10, 2020Aspirant
C7800 2.4Gz Network goes to channel 0 and stops working
This has been a consistent behavior. At some point during operation the 2.4 Ghz Network goes down into channel 0. I use it on auto. I cant change the channel after it fails. I try and it does not...
vkdelta
Aug 11, 2020NETGEAR Employee Retired
can you set it to specific channel instead of AUTO? such as CH7, CH4, etc.
GerryPedraza
Aug 12, 2020Aspirant
I can try a specific channels. Thanks for the suggestion.
I think I read somewhere to leave it auto, but I can start to try channels in order and check if one of these does not break. I'll post my results.
Thank you,
G
