GerryPedraza
Aug 10, 2020Aspirant
C7800 2.4Gz Network goes to channel 0 and stops working
This has been a consistent behavior. At some point during operation the 2.4 Ghz Network goes down into channel 0. I use it on auto. I cant change the channel after it fails. I try and it does not...
Aug 24, 2020Guru - Experienced User
Try channels 1, 6 or 11 and see if ths helps the PS4.
Wired is preferred for gaming consoles.
GerryPedraza
Aug 25, 2020Aspirant
Thanks for the recommendations. I'll try these settings. I first want to get the Internet connection better. For some reason I have been getting 1 MB download speed. I switched to my old modem and I got 300 so there is something that got messed up when factory settings were applied.
