702dani
May 26, 2021Guide
C7800 Access Denied / No Wifi firmware update
Bought the C7800 a few days ago. Connected, setup - worked great for a few days with Xfinity 1GB plan. The app said “firmware out of date” and to login to admin to update, but there was no option. Sup...
May 27, 2021Guru - Experienced User
The firmware for the C7800 is built into the partitioning file from the ISP when the set it up. so they one they have, is the one you'll get.
To try to get it working, try this.
Disconnect everything from the C7800 including the coax cable. (leave the power cable)
While powered on, push and hold reset for up to 30 seconds. let it reboot.
Once fully rebooted (all light stablized), then power it down, wait 2 minutes, connect the coax to it, and power it back on.
Wait a couple minutes for it to fully boot.
then attempt to access/set it up.
702dani
May 27, 2021Guide
Thank you for the advice! It did not work. Unfortunately it is the same, bit sure if it has to do with the file from the ISP. But it is locked on downstream and shows Connectivity - Access Denied. Xfinity tech support says they can see the modem online. However the Nighthawk app still says “Firmware out of date” (it always has, though, even when it was working perfectly. I am wondering if Xfinity is just not compatible with this model?
