702dani
May 26, 2021Guide
C7800 Access Denied / No Wifi firmware update
Bought the C7800 a few days ago. Connected, setup - worked great for a few days with Xfinity 1GB plan. The app said “firmware out of date” and to login to admin to update, but there was no option. Sup...
702dani
May 27, 2021Guide
Thank you for the advice! It did not work. Unfortunately it is the same, bit sure if it has to do with the file from the ISP. But it is locked on downstream and shows Connectivity - Access Denied. Xfinity tech support says they can see the modem online. However the Nighthawk app still says “Firmware out of date” (it always has, though, even when it was working perfectly. I am wondering if Xfinity is just not compatible with this model?
May 27, 2021Guru - Experienced User
Xfinity is compatible with that model. I've used it on xfinity before.
Ignore the "firmware out of date" notice. Genie is horrible at sending that notice. and the .43 is the current one for xfinity.
You're able to log into it fine?
Do you still have your old modem?
Try reactivating that to the account. Then switch back to the c7800.
- 702daniMay 27, 2021GuideThanks! Tried and nothing.
Switched everything back to old xFi gateway - worked.
Then tried to setup the Nighthawk and got the same problem. No connectivity... downstream locked, upstream stays scanning/blinking, and Connectivity says Access Denied.
Xfinity is also no help. They only give the option to send one of their techs out in a few days for $100.
