Galactus1967
May 14, 2020Follower
C7800 Access to Admin from the Internet
Nighthawk X45 AC3200 WiFi Cable Modem Router Can someone help provide or point to instructions that will allow me to access my device's admin page from the Internet? Thanks!
May 14, 2020Guru - Experienced User
I would review the user manual to see if this information is posted there.
Look under the Advanced Tab/Advanced Settings and Remote Management will be where you need to set this up. Should be as easy as enabling it and it will give you a WAN IP address:port # to use from remote locations.
