duck_hook
Oct 07, 2019Aspirant
C7800 and Mediacom Gigabit Internet
Does anyone have experience with a C7800 on a Mediacom Gbit cable connection? Looking for recommendations on a modem wifi router combo that will work well with Mediacom Gbit. No phone connectivity ne...
duck_hook
Oct 08, 2019Aspirant
Yes and that makes sense. What two devices would you recommend? Looking to cover about 2000 sq ft of house space with the need to have signal in the basement.
Oct 08, 2019Guru - Experienced User
https://www.netgear.com/home/products/networking/wifi-routers/
Check out what routers may fit your needs.
Do you already have the C7800 modem? If so, and if your ISP can ensure it gets 1Gb on the WAN to LAN side, you could put the modem in modem only mode then connect up a external router. The R7800 handles Gb speeds WAN to LAN. XR450 and 500 do as well. However those are gaming routers.
