Jagga
Dec 31, 2019Aspirant
C7800 Bootfile Error
Xfinity/Comcast stated that speeds(1GB) on their end was good and that my router had a "Bootfile Error" that Netgear should be able to correct that is not allowing all the speed to come in. Any help...
michaelkenward
Jan 01, 2020Guru - Experienced User
You might find it useful to look in the appropriate place for your C7800 . That is a cable modem/router, not one of the "Nighthawk WiFi Routers" that this section is for.
You might find other answers over in the appropriate section for your device:
Cable Modems & Routers
