jeffmarks
Nov 28, 2022Aspirant
C7800 BRICKED
I've had my C7800 for about a year with very few problems until a few weeks ago. I'm not sure if it was firmware or just hardware malfunction but there is no signal reaching this unit. My ISP is Xfin...
Nov 29, 2022Guru - Experienced User
The C7800 I believe needs to connect back to the ISP or it reboots trying to fix it.
Did you have the ISP initialize the modem? (since you switched back to your other device)
Also, if you have the working modem connected, do you have a screen snip of its cable connections page and event logs?
Maybe if the signal isn't good enough, the c7800 is failing its connections check.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
jeffmarks
Dec 10, 2022Aspirant
Thank you for the reply. Nice to finally have someone pay attention. Netgear pushes the responsibility on Comcast and Comcast isn't helping. My older modems power levels are as such:
- jeffmarksDec 10, 2022Aspirant
I removed the board from the c7800 to look for any sign of visible trouble but also tested the coax port for a short and the one question I would like to ask if anyone knows after plugging in a test cable and doing a continuity test the entire metal box surrounding the coax input port is hot (receiving the coax signal) is this normal or do I have a short?
- FURRYe38Dec 11, 2022Guru - Experienced User
If you happen to have a coax line splitter, you can connect one of these off the main line and connect up a working modem to the splitter and have service, then you can hook up the C7800 to the other line on the spliter for just signal thats not associated having the C7800 with the ISP service. Use this only as a temporary test or check.
However, you don't need to have the C7800 modem connected to any coax ISP as the modem should boot to a ready state for you to access the UI, IF it's in a good state.
Responsibility IS on the ISP side for there signal and line services UP to the modem along with FW updates as users are not allowed to update gateway cable modem FW at all. FYI, some ISPs will work with user owned modems, however be aware that some ISPs will not.
