CihanKayacan's avatar
CihanKayacan
C7800 bridge mode
I got to use the C7800 model in Turkey. I can't use it now. When I called the Internet service, I was asked if they supported Eurodocsis.
Can I use this product in Turkey? Is the problem getting the Docsis 3.0 service? What should I do to use?
  • Can i change in router US Freq Range 5-42 MHz to 5-85 MHz ?
    Or in SNMP can i change myself?
    • vkdelta's avatar
      vkdelta
      NETGEAR Employee Retired
      C7800 is not EU-DOCSIS certified. We dont claim it will work.
      for US diplexer switch, it can be done via SNMP by the ISP (not by user). by default it should be 5-42MHz
