Jmurray32168
Jun 21, 2020Aspirant
C7800 cable works no internet no WiFi
C7800 internet connected No info in or out I have a netgear nighthawk C7800. It just quit exchanging data over the web. Called xfinity the signal is good. We have cable tv in all rooms works fine. We...
- Jun 23, 2020
ok.
Jun 21, 2020Guru - Experienced User
Do you get internet access and services with a direct wired PC connected to the back of the modem with out this switch?
What is the model# of this switch your using?
I have a netgear nighthawk C7800. It just quit exchanging data over the web. Called xfinity the signal is good. We have cable tv in all rooms works fine. We have 4 computers connected to this router through a D-link switch. So cable into the router line out to switch. Cat5 from my laptop to router. Cycled power on router 4-5 times yesterday. Cycled power on all desktops and the switch several times. Computers all say connected to netgear. Phones al show full strength connection to WiFi. Netgear genie shows cable connection stays good. BUT here’s the kicker no information in or out. All web browsers time out and you must turn WiFi off on phones and use 4glte
Jmurray32168
Jun 23, 2020Aspirant
No. But for some odd reason everything came back up Sunday night. I think it was comcast
- FURRYe38Jun 23, 2020Guru - Experienced User
Ok. Glad it's working again. Mark your thread as solved so others will know.
Enjoy. :smileywink:
- Jmurray32168Jun 23, 2020Aspirant
ok.
