Jmurray32168
Jan 04, 2021Aspirant
C7800 CABLE WORKS NO INTERNET NO WIFI
I'm still having this problem. Had Comcast out yesterday and they replaced the entire line and I'm still having issues. Can you help me make sure the router is operating correctly?
Jan 04, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and the event logs?
that helps check the connection.
