zatan
Feb 01, 2022Aspirant
C7800 cable works no internet on WiFi
Problem happen many time this month and started few month ago. My wifi works for few devices. Some devices like iphone 12, ipad and laptop lost connection, dont seem to have ipv4 address asigned. ...
Feb 01, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
zatan
I am set to channel 1 and 149
neighbors are on different channel.
- zatanFeb 01, 2022Aspirant
I also have netgear genie App on my phone, its connected to the wifi but seems to not able to connect to the c7800 to manage it.
- FURRYe38Feb 01, 2022Guru - Experienced User
Either use the Nighthawk app or log into the modems web page with a PC or laptop and web browser at 192.168.100.1 or 192.168.0.1.
Yes, I know how to do all that, plus reseting the c7800. Is there some thinking out of the sandbox solutions. I have read all of your replies on this netgear community related to the c7800. There seems to be a issues with xfinity and this c7800, do you think so?
IF reboot or reset is the best option, then netgear should provide a option to schdule a reboot every night or every week. Best done at night when no one is a wake, (kids online classes, I am work at home)
