khamilton315
Jul 18, 2020Guide
c7800 disconnecting often
Bought the C7800 Nighthawk in Feburary of 2020 brand new. Everything was great, could not ask for any better performance. Last week I started losing connectivity to it. Xfinity cable internet is up a...
- Jul 21, 2020The internet has worked flawlessly since the technician arrived. It was definitely on the ISP’s (Comcast/Xfinity) end. Haven’t dropped once in the last two days and performance is better. Definitely check where your power level is on the downstream and the upstream.
Also I believe some of the tweaks Furry had me do helped performance.
Thanks again Furry, appreciate your time.
Jul 18, 2020Guru - Experienced User
Is both wired and wireless devices experiencing this?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
khamilton315
Jul 18, 2020Guide
Yes, both wired and wireless are experiencing this.
Yes the channel was on Auto and I changed it per your suggestion.
How do you know if a channel is unused to assign it to the 5Ghz?
Yes, it appears I can see three to four neighbors Wifi available.
Comcast/Xfinity has tried many things on their end and they say everything is good until it drops connection. This happens when I'm actually talking to them and they see it. I do not believe there is any "splitters" used and they are sending a technician Monday to check my lines.
- khamilton315Jul 18, 2020Guide
Also Netgear states my upstream power is too low. There are 4 channels locked and they very from 31 to 34.
My downstream power is too high. there are 32 channels locked and they vary from 5's to as high as 8.4
Netgear provided me the proper performance, upstream 45-48 and downstream -7 - +7.
Netgear stated this can only be corrected by the ISP (Xfinity). Called Xfinity and they had no clue what I was talking about and referred me back to Netgear.
- FURRYe38Jul 18, 2020Guru - Experienced User
Ya, your ISP needs to look at your signal on the line. There playing hard to get/stupid and it's there responsibility on the there side of the fence. I would ask for excalated support or someone else. Modem mfrs can't control any thing on the ISP side of the fence.
Can you refer to message 3 of our thread. I answered most of your questions. I did ask you, how do you know if a channel is "unused" to assign it to the 5Ghz.
