khamilton315
Jul 18, 2020Guide
c7800 disconnecting often
Bought the C7800 Nighthawk in Feburary of 2020 brand new. Everything was great, could not ask for any better performance. Last week I started losing connectivity to it. Xfinity cable internet is up a...
- Jul 21, 2020The internet has worked flawlessly since the technician arrived. It was definitely on the ISP’s (Comcast/Xfinity) end. Haven’t dropped once in the last two days and performance is better. Definitely check where your power level is on the downstream and the upstream.
Also I believe some of the tweaks Furry had me do helped performance.
Thanks again Furry, appreciate your time.
Jul 18, 2020Guru - Experienced User
Ya, your ISP needs to look at your signal on the line. There playing hard to get/stupid and it's there responsibility on the there side of the fence. I would ask for excalated support or someone else. Modem mfrs can't control any thing on the ISP side of the fence.
khamilton315
Jul 18, 2020Guide
Can you refer to message 3 of our thread. I answered most of your questions. I did ask you, how do you know if a channel is "unused" to assign it to the 5Ghz.
- FURRYe38Jul 18, 2020Guru - Experienced User
Install a wifi analyzer on a pad, apple or android. Check to see who around is using 5ghz channels.
- khamilton315Jul 18, 2020Guide
That worked great on finding the channels with less traffic. Much appreciated on that. Also I'm on hold with excalated support. Appreciate that one too. You've been a great help. Appreciate your time and helpfulness. I do not know at this time if it has helped my situation but I feel much better, more educated. Again, Thank you!
Hopefully ISP will get it figured out.
Good Luck.
