khamilton315
Jul 18, 2020Guide
c7800 disconnecting often
Bought the C7800 Nighthawk in Feburary of 2020 brand new. Everything was great, could not ask for any better performance. Last week I started losing connectivity to it. Xfinity cable internet is up a...
- Jul 21, 2020The internet has worked flawlessly since the technician arrived. It was definitely on the ISP’s (Comcast/Xfinity) end. Haven’t dropped once in the last two days and performance is better. Definitely check where your power level is on the downstream and the upstream.
Also I believe some of the tweaks Furry had me do helped performance.
Thanks again Furry, appreciate your time.
nrami016
Jul 19, 2020Aspirant
Hi, do you mind updating this thread if your issue has been resolved? I am on the same boat as you are with the random disconnects from the router... The router is a beast but the disconnection issues are detrimental to the user's experience.
Just making sure that it is not the router before I return it; I received it yesterday and almost immediately I began noticing the random drops from either 5 Ghz or 2.4 Ghz.
Thanks in advance,
Neil
Jul 19, 2020Guru - Experienced User
Is both wired and wireless devices experiencing this?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
nrami016 wrote:Hi, do you mind updating this thread if your issue has been resolved? I am on the same boat as you are with the random disconnects from the router... The router is a beast but the disconnection issues are detrimental to the user's experience.
Thanks in advance,
Neil
- khamilton315Jul 19, 2020Guide
No, this has not resolved the issue. Although it is better it has dropped a few times today. I have a technician from my ISP coming tomorrow morning.
- FURRYe38Jul 19, 2020Guru - Experienced User
Good. Hopefully he can narrow it down where the problem is. Ask him to take a look at the connect status of the modem while he's there too.
Keep us posted.
- nrami016Jul 19, 2020Aspirant
Furry,
Hi. I'm not sure what happened to my original reply back to you. In any case:
While using the C7800 [firmware V3.01.43], I was using 'Auto'. I did try the suggestions you offered below and I did a channel refresh, which switched to different channels. I did not set things up manually. Also, thanks to you I did learn how crowded the radio field is nearby my house; now I can set the router to a channel that is not crowded.
I proceeded to call Comcast and though I couldn't get my call escalated to 2nd/3rd level, the tech did find that the SNR/Power ranges were a little high for the UP stream (something new I learned).
The tech sent a new router configuration, which did help with the unit auto restarting/rebooting on its own but it did not fix the issue. I then proceeded to remove the splitter between the main cable drop from the pole to the house, and that also helped somewhat but the problem remained.
After many minutes troubleshooting things around, I decided to go back to my old modem C7000v2 to test if actually the coax or the splitter or something else was off.. to my surprise, my old cloncker picked up from where I left it off yesterday and haven't have a reboot/restart/dropped signal issue yet.
The only reason why I tried upgrading to the C7800 was for the added horsepower it brings but I guess something is off with some of these units. Although mine's was bought as a refurb unit (I learned this after the fact, no excuses), I've seen people who have bought these new from Netgear and also are experiencing the drop out/disconnect/restart issues as well.
Thank you for the troubleshooting guide and for your help.
Best regards,
Neil
FURRYe38 wrote:Is both wired and wireless devices experiencing this?
Any Wifi Neighbors near by? If so, how many?Have the ISP check the signal and line quality UP to the modem.
Be sure your using good quality RG6 coax cable up to the modem. - khamilton315Jul 20, 2020Guide
Comcast/Xfinity was here promptly at 8am. They did their outside check and noticed that my downstream power was too high and upstream power too low (He was the first person to actually say those terms and understood that worked for Comcast, which made me feel better that someone knew what they were talking about). They did some work on their end and replaced some lines and I believe replaced my outside box. The downstream power is in the noraml parameters now. The upstream is just slightly lower than the netgear parameters now, but much better than what they were. Their correction raised it from low 30's power to 40's with one 39 but not up to 45-48 where netgear recommends. The technician stated he could not get it any higher than that and that was Comcast normal parameters now.
I will update this later today or tomorrow to let you all know if this corrected my issue of disconnecting service often.
- FURRYe38Jul 20, 2020Guru - Experienced User
I recommend returning the C7800 as its a refurb and may have additional problems. Not everyone has problems with the c7800 rebooting. Mine worked well for a long time before taking it off line.
I recommend that if you want better wifi horse power, keep your C7000, configure it for modem only mode and install a external wifi router. You have more choices and more control over the wifi router than you do with gateway modems.
- khamilton315Jul 21, 2020GuideThe internet has worked flawlessly since the technician arrived. It was definitely on the ISP’s (Comcast/Xfinity) end. Haven’t dropped once in the last two days and performance is better. Definitely check where your power level is on the downstream and the upstream.
Thanks again Furry, appreciate your time. - FURRYe38Jul 21, 2020Guru - Experienced User
Glad to hear the ISP got things working better for you. You should be good now.
Please mark your thread and solved so others will know.
Enjoy, :smileywink:
