khamilton315
Jul 18, 2020Guide
c7800 disconnecting often
Bought the C7800 Nighthawk in Feburary of 2020 brand new. Everything was great, could not ask for any better performance. Last week I started losing connectivity to it. Xfinity cable internet is up a...
- Jul 21, 2020The internet has worked flawlessly since the technician arrived. It was definitely on the ISP’s (Comcast/Xfinity) end. Haven’t dropped once in the last two days and performance is better. Definitely check where your power level is on the downstream and the upstream.
Also I believe some of the tweaks Furry had me do helped performance.
Thanks again Furry, appreciate your time.
Jul 20, 2020Guru - Experienced User
I recommend returning the C7800 as its a refurb and may have additional problems. Not everyone has problems with the c7800 rebooting. Mine worked well for a long time before taking it off line.
I recommend that if you want better wifi horse power, keep your C7000, configure it for modem only mode and install a external wifi router. You have more choices and more control over the wifi router than you do with gateway modems.
khamilton315
Jul 21, 2020Guide
- FURRYe38Jul 21, 2020Guru - Experienced User
Glad to hear the ISP got things working better for you. You should be good now.
Please mark your thread and solved so others will know.
Enjoy, :smileywink:
