MMC2019's avatar
MMC2019
C7800 doesn't like LAN Range IP change
I have a customer with a C7800 modem/router.    I have a large amount of network gear there, so I changed the LAN IP range to 192.169.1.x.   The router default was 192.168.0.x.    When I change it,  ...
  • antinode's avatar
    antinode
    Dec 11, 2019
    > [...] router no longer accessible locally via the 192.168.1.1 address,
       Regarding "no longer", see "not a useful problem description", above.
    >    After you changed whatever you changed, did you restart the
    > (unspecified) computer where you were doing this work?  What is its IP
    > address?
       Still mysteries.
    > [...] should not be required to do so. [...]
       I agree, but that doesn't answer any of the pending questions.
