IThinkImMe
Jan 28, 2020Aspirant
C7800 Dropping ISP connection
Been having a recurring issue with the connection to my ISP randomly dropping. Here are some of the facts: ISP: Wave Broadband Plan: 1GB/10mb Router never loses power Usually comes back within 60...
IThinkImMe
Thanks for replying. I would like to state that I had another router previously that had the exact same symptoms as this one. Not sure of the exact model but it was an older Nighthawk. Support said I needed to update because it was DOCSIS 3.0 and my gig plan requires DOCSIS 3.1.
Jan 28, 2020Guru - Experienced User
I would try another C7800 to see if this problem persists.
IF a different modem did, there could be problems from where you modem is up to the ISP service box. Though I kind of doubt this.
Trying of another C7800 should reveal something.
- Jarudegirl1Jun 05, 2020Aspirant
Hello,
My ISP is sayig the same thing about this router. When they put a Arris 3.1 on line, the SNR look fine. But with this NightHawk C7800. The tech from Atlantic Broadband said something about the SNR is registering 0 downstream on the 25 port downwards yet on the Arris modem he used not issue with the SNR.
My symptoms are peroidic connection drops.
Ex. Monday between 8am - 6pm, every 30 mins. Yet, the next day til today Friday functions fine.
So i really wonder if its the router or the ISP.
This issue have been happening every month at this time (4-10th day).
Right now, its working fine.
AM256 1 285000000 Hz 4.8 dBmV 38.8 dB 49 243 3 Locked QAM256 2 291000000 Hz 4.8 dBmV 38.6 dB 62 235 4 Locked QAM256 3 297000000 Hz 4.8 dBmV 38.5 dB 138 717 5 Locked QAM256 4 303000000 Hz 4.8 dBmV 38.4 dB 56 231 6 Locked QAM256 5 309000000 Hz 4.7 dBmV 38.4 dB 56 238 7 Locked QAM256 6 315000000 Hz 4.6 dBmV 38.3 dB 42 250 8 Locked QAM256 7 321000000 Hz 4.6 dBmV 38.4 dB 55 245 9 Locked QAM256 8 327000000 Hz 4.8 dBmV 38.3 dB 62 239 10 Locked QAM256 9 333000000 Hz 4.9 dBmV 38.4 dB 73 311 11 Locked QAM256 11 345000000 Hz 5.4 dBmV 38.4 dB 78 366 12 Locked QAM256 12 351000000 Hz 5.4 dBmV 38.4 dB 68 341 13 Locked QAM256 13 357000000 Hz 5.3 dBmV 38.2 dB 78 355 14 Locked QAM256 14 363000000 Hz 5.5 dBmV 38.1 dB 68 369 15 Locked QAM256 15 369000000 Hz 5.5 dBmV 38.1 dB 82 368 16 Locked QAM256 16 375000000 Hz 5.5 dBmV 38.0 dB 75 384 17 Locked QAM256 17 381000000 Hz 5.5 dBmV 38.0 dB 74 396 18 Locked QAM256 18 387000000 Hz 5.6 dBmV 37.9 dB 78 378 19 Locked QAM256 19 393000000 Hz 5.5 dBmV 37.9 dB 83 365 20 Locked QAM256 20 399000000 Hz 5.5 dBmV 37.9 dB 91 370 21 Locked QAM256 21 405000000 Hz 5.5 dBmV 37.8 dB 81 363 22 Locked QAM256 22 411000000 Hz 5.6 dBmV 37.8 dB 72 384 23 Locked QAM256 23 417000000 Hz 5.6 dBmV 37.7 dB 68 372 24 Locked QAM256 24 423000000 Hz 6.1 dBmV 38.0 dB 81 362 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1> Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 6 5120 Ksym/sec 32000000 Hz 46.5 dBmV 2 Locked ATDMA 5 5120 Ksym/sec 38400000 Hz 47.0 dBmV 3 Locked ATDMA 7 5120 Ksym/sec 25600000 Hz 46.5 dBmV 4 Locked ATDMA 8 5120 Ksym/sec 19200000 Hz 46.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords 1 159 Non-Primary 419600000 Hz 296 ~ 7895 130412291 57091 2 0 Other 0 Hz 0 ~ 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power 1 Other 0 Hz 0 ~ 0 0 0 dBmV 2 Other 0 Hz 0 ~ 0 0 0 dBmV Current System Time: Fri, Jun 05, 2020 15:24:06 - FURRYe38Jun 05, 2020Guru - Experienced User
Make contact with NG support about an RMA if thats possible.
Jarudegirl1 wrote:Hello,
